Subframe diet
Old Feb 23, 2006 | 03:26 AM
DSNUT's Avatar
Default Subframe diet
Originally posted by: sandbomber
Sorry I did not have a chance to weight the sub frame but will soon!! Having a few built right now for a couple guys!! Should have an answer in about a week. I will say 12+ pounds saved and they will work for dune riding but the battery will have to be relocated.
What happens if you get stuck out there? Is the subframe strong enough to withstand me horsing my bike around by the rear grab bar?
Thanks for the info,
Ron
Old Feb 23, 2006 | 07:53 AM
choosetolose04's Avatar
Originally posted by: FatHolly
Choose, Aluminium or C-moly?
Aluminum and no, you cannot horse it around if you get stuck. Its strictly drag race only.
Old Feb 23, 2006 | 12:05 PM
sandbomber's Avatar
Ron this sub frame is fairly strong, I have not tested it to its limits with my bike only weighting 315 but the grab bar is how we jerk the bike around
Old Feb 23, 2006 | 12:06 PM
1BigDSRider's Avatar
Originally posted by: BajaX04
I think we should all post a picture of every part sitting on a scale to verify weight. I have read so many times that if you remove your front fenders and supports you save like 14 pounds!! Then I took mine off and weighed them I cant say that number to be exact but it is really like 2 pounds together! Its like the bike lenghts gain I also hear...6 bike lenghts on the hill.....right.....
Baja, I removed my front fenders and I will weigh them as soon as I can with bolts and brackets. My bike will be going on a big diet sometime after Planet Sand. I plan on weighing everything so that I can see just how much weight my ds looses. I will post all weights, stock and modified.
Weight loss program for my Ds.
Front brakes removed
Front fenders removed
Trimed rear plastics
On dunes Subframe
On dunes drag a-arms and spindles
Lightweight drag axle
new rear hubs
Light weight tripple buff rear tires
jr. dragster front tires
On dunes steering stem
Lights removed
Front bumper removed
Light weight chain
new lighter sprockets
drag handle bars
Trim extra brackets off the frame
light weight fuel tank
Shooting for an overall weight under 350 lbs fully fueled.
Old Feb 23, 2006 | 12:37 PM
  #15
DSNUT's Avatar
That sounds good enough. That will get my bike down to a fully dunable 400 lbs wet!!! I can afford to show the grab bar a little respect for a 12 lb weight savings.
Thanks Glenn!
crt1raptor
Sep 15, 2003 09:16 AM
rippinrap
Jun 10, 2003 10:30 AM
NotuRaptor2
Sep 15, 2002 12:43 PM
TrailMix
May 8, 2001 09:23 PM
hakmazter
Aug 11, 2000 02:56 AM
