East Coast DS Days - Silver Lake Sand Dunes
#51
Does any one know the main jet to use at silver lake? I have a dyno jet kit and running a 185 main jet. Is that going to be ok or will it lack power and bog down?
#52
Thanks hightower. [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
#53
As for the jetting question steve. I would think that your 185 is way to big for the modds you have listed. I have a filter and a pipe and only have a 172 or 175 m/j. With just a filter you shouldnt need to rejet, I know I didnt. Try putting the stock 1 back in.
#54
#55
Not to be a smarty pants, but advertisement is just that. Your quad is a basic stocker. The stock m/j is I believe a 165. I am not sure if your jet kit measures out the same as the mikuni jets. But check your plugs and go from there. I have listed what is done to mine and I only run a mikuni 172 or 175 and mine may be on little on the rich side but just a tiny bit. I weigh 150lbs and can pull big hills in 3rd without full throttle and never bogs. A friend of mine weighs 220 and he also has rode it up the same hills with no problem. A big jet means nothing unless you need one that big. Like I said before, I would do a plug check and go from there. Hope ya getter figured out. RUSS
Oh ya if you are having to idle it high until it warms up then I think you need to adjust your idle screw, this will help when starting and idling and 1/4 throttle performance.
#56
when I had the stock jet in, I would bog down in 3rd going up test hill. I do weigh in about 215. But I will swap out the jet and try that. I need a tach tool to help with the tuning in the carb. Thanks for the input!!
#57
Check this site out to determine the size of jets. Your running about the same jet as I am.
Dyno vs. Mikuni
#58
Thanks for the link. Well that is right we are running the same size jets. I think you still need to do a plug check. I was just helping a guy get his raptor figured out last night, it is big bored and everything else with a edelbrock and he was runnin way rich. I use a laser temp gun to read temps of exaust and engine and read the plugs. Reading the plugs is one of the easiest ways to determine a rich or lean state. Keep us posted. RUSS
