DS Kickback
Old 06-14-2006 | 05:55 PM
H0nDo's Avatar
Default DS Kickback
Im having problems with my 04 DS 650. I get a too many kickbacks when im starting it. It is 100% stock and i took the starter off and the starter gears and the gear inside the motor don't look tore up at all..Please help me with a solution for this
Thanks
Seth
Old 06-14-2006 | 08:06 PM
atvaddict01's Avatar
Default DS Kickback
Raise your idle it should stop.
Old 06-14-2006 | 11:40 PM
chirochris's Avatar
Default DS Kickback
to what?
Old 06-15-2006 | 12:28 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Default DS Kickback
To help your motor start best:
1. Put dielectic grease on battry connections and reg/rectifier connections.
2. Put battery charger on battery if you let sit for more than 5 days. Or buy a battery tender.
2. Keep your idle 1450-1500rpm. Butterfly covers low speed orifices and causes motor to load up if it doesn't start right away. When you release starter a large amount of voltage goes to the spark plugs and because motor is turniing very slow, it will cause the motor to turn backwards. Poor starter takes a hit.
What type of spark plugs are you using?
Replace often. Do not try to see how long they will last.
How to set the rpm's without tach:
When the motor is warm and you shift into 1st gear-
If goes into gear very smoothly and no sounds or jerking - Rpm's too low
If goes into gear and makes a light clunk sound - Rpm's just right
If goes into gear and makes a hard clank sound and motor/quad moves - Rpm's too high
Old 06-15-2006 | 06:41 PM
BioWare's Avatar
Toxic Ryder
Default DS Kickback
I learn something new every day.
Thanks
OMR
tcgravy
04-30-2015 05:24 PM
mikelikenos
01-27-2006 12:26 AM
hitman1970
08-26-2004 12:28 AM
kawakasi
05-14-2004 10:04 PM
nyroc
04-28-2004 03:39 PM
