problems
Old Oct 28, 2007 | 09:41 PM
McKay5858's Avatar
Default problems
So i was out on a tour today and after a couple of hours of running really well my 2000 ds went sour. suddenly it started chokin out when i tried to give it throttle, it idles perfect but if you give it gas after about 3 seconds its like its running out of fuel. I havnt taken anything apart yet but could this be a fuel issue? also after it did this for a while i shut it off, wiggled the battery connections and started it back up it worked fine for maybe a mile down the road then it started again, which leads me to think it could maybe be electrical? any ideas or suggestions would be great thanks
Old Oct 28, 2007 | 11:00 PM
cynick's Avatar
Default problems
Try running the bike with the gas cap off it sounds like the tank vent is plugged.
Old Oct 28, 2007 | 11:08 PM
SANDMAN430's Avatar
Default problems
if it is the stock carb it sounds like the rubber diaphram may have a hole. it is under the round cap on top of the carb just pull the 4 screws to check
Old Oct 29, 2007 | 01:49 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default problems
Check the battery - first make sure both cables are tight, then check the charge of the battery. The DS will idle for ever but the ignition will not advance with a poor(dead) battery or a bad connection to it.
Old Oct 30, 2007 | 01:41 AM
McKay5858's Avatar
Default problems
i just checked my battery, the ground connection was snapped right in two, thanks for the advice guys!
Old Oct 30, 2007 | 10:27 AM
MRDS650's Avatar
Default problems
no worries - Welcome to the Forums !!!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
