hey guys! new to the forum
thinking about putting lte dual exhuast on my ds. it is stock. any info. would help, does the air box have to be completely removed or is there any other aftermarket availble?and the jet kit comes with it and after installed good to go or is it recomended to have it dyno and fine tuned?is there any other mods you have to do to install the duals?
Yes you have to remove the whole airbox, and infact you have to get a Direct mount filter for your Carb. The snorkle tube will not fit either. Also, you will have to do a little bit of cutting on the frame to allow the LTE pipe to fit. They lookand sound great, so it would be worth it.
<div class="FTQUOTE"><begin quote>Originally posted by: DragonDJ11
Yes you have to remove the whole airbox, and infact you have to get a Direct mount filter for your Carb. The snorkle tube will not fit either. Also, you will have to do a little bit of cutting on the frame to allow the LTE pipe to fit. They lookand sound great, so it would be worth it.</end quote></div>
wow,...im glad i chose to go with rwr,...but they do look good!!!
<div class="FTQUOTE"><begin quote>Originally posted by: joe dirt
wow,...im glad i chose to go with rwr,...but they do look good!!!</end quote></div>
And sewriously the coolest sounding pipe I have heard on the DS to date. But yes, a lot of work to get them on....
toonces
10-16-2019 12:11 PM
skittero
35
03-01-2019 12:39 AM
