2001 dS650 RED LIGHT
Old Jun 13, 2008 | 07:01 PM
speedfreak1088's Avatar
Default 2001 dS650 RED LIGHT
I WENT RIDING LAST NIGHT AND AFTER 30 MINUTES OR SO THE RED LIGHT CAME ON BY THE KEY SWITCH,IS THIS A LOW OIL LIGHT OR OVERHEATING,AND STOP AND WAITED 10 MINUTES AND IT WENT OFF,IVE HEARD THE DS'S HAVE A PROBLEM WITH A SWITCH OR RELAY TO THE FAN??????ANY HELP IS APPRECIATED,THANKS.ONE MORE THING WHERE DO YOU CHECK THE OIL AT ON THIS THING !!!!!!
Old Jun 13, 2008 | 08:26 PM
jusrlax's Avatar
The red light can be either low oil pressure or excessive coolant temperature. The oil dipstick is on the left side (when looking from the rear) and is between the black dash (where the key and the red light are) and the front fairing. The dipstick is black.
Old Jun 13, 2008 | 09:22 PM
Ok the oil level looks fine,maybe the fan didnt kick in,where is the coolant level check at
Old Jun 14, 2008 | 12:09 AM
jusrlax's Avatar
The oil level may be fine, but you may not have good oil pressure. Run the motor and take the dipstick out. Look into the tank and see if you can see the oil cavitating back from the the return line. If not, your oil pump may be bad. You may have a bad oil pressure sensor, which causes the red light to stay on. The sensors go bad most often from getting wet, like if you washed the bike. The oil pressure sensor is located on the back part of the motor, in the center facing up. It is black, and has a little wire that attaches to the top of it. Look beyond where the colored heat shield attaches to the header pipe, and you should see it. A new one costs about $12 from the dealer.
On the right side of the bike, looking from the rear, you will see both the radiator cap and the clear overflow reservoir. You need to check the coolant level in both of these. Good luck.
Old Jun 14, 2008 | 12:15 AM
Roughneck1's Avatar
Have you changed the oil lately? I had the same problem last week come to find out their is a bleeder screw right next to the oil filter that bleeds the air out of the system. Bled that and everything has fine since.
Old Jun 14, 2008 | 12:32 AM
thanks guys Ill check out the things you mentioned
Old Jun 14, 2008 | 02:44 AM
SW2steve77's Avatar
One thing to check also is your electric coolant sensor. The shop manual says you can check this with a propane torch and a multimeter. Measure the resistance between connector on the top of temperature sensor and threads. The multimeter should indicate an infinite resistance (O.L.), if not change the temperature sensor. Next, heat the temperature sensor above 115°C (239°F). The resistance should be 0.1 ohms. If not, change the temperature sensor.
MRDS650
Feb 22, 2026 11:26 AM
Hunter100us
Oct 7, 2015 11:46 PM
Pahuntman
Sep 5, 2015 11:07 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
maxjung
Jul 14, 2015 03:10 AM
