Handlebar Question
Old Jul 10, 2008 | 07:55 PM
jusrlax's Avatar
Default Handlebar Question
Last weekend, I replaced the bent handlebars on my 04, with some Pro-Tapers in ATV mid-bend. When I installed them, using only the stock handlebar clamps and bolts, they felt a tad low and hit the tank a little bit on a lock to lock turn. To fix this, instead of buying a fancy riser, I went to the hardware store and got four 3/4" metal spacers and four longer bolts. I placed the spacers on top of the metal plate that the stock clamps bolt to, put the stock clamps on top of the spacers, and put it all together with the four longer bolts. This raised the bars 3/4", they sit high enough now, and hardly hit the tank. My only worry is if this is safe. Are the fancier risers somehow stronger/safer than shimming them up the way that I have? Any input would be appreciated.
Old Jul 10, 2008 | 09:21 PM
DS650ryder's Avatar
eh the riser is probably stronger but i dont think you will have a problem, i thought about doing this at one point but never did, as for safety i dont see how any would be any less safer than a riser.
Old Jul 11, 2008 | 12:28 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
I would definantly use grade 8 bolts if you did this.
Old Jul 11, 2008 | 01:06 PM
jusrlax's Avatar
I got the bolts from Ace Hardware, and they have "8.8" stamped on the head, just the like the shorter stock ones I replaced did. This means Grade 8, correct?
<div class="FTQUOTE"><begin quote>Originally posted by: Tpsycho
I would definantly use grade 8 bolts if you did this.</end quote></div>
Old Jul 11, 2008 | 01:32 PM
Tpsycho's Avatar
hardened bolts grade 8 have six lines on top of the bolt head.
http://www.portlandbolt.com/te...ication_markings.html
This is a adress to a bolt ID chart. Hope this help's you out.
Old Jul 11, 2008 | 01:41 PM
jusrlax's Avatar
I appreciate the link. I will check for those lines on the bolts that I bought. I had no idea buying four bolts could become so complicated....lol.
<a target=_blank class=ftalternatingbarlinklarge href="http://www.portlandbolt.com/technicalinformation/fastener_identification_markings.html
">http://www.portlandbolt.com/te...n_markings.html
</a>
This is a adress to a bolt ID chart. Hope this help's you out.</end quote></div>
Old Jul 12, 2008 | 12:27 AM
jusrlax's Avatar
Looks like "Grade 8" is specific to standard bolts, not metric. After researching this, it looks like Grade 8.8 in a metric is roughly equivalent to Grade 5. I switched to standard Grade 8 bolts and nuts, and now I should be good to go.
Old Jul 12, 2008 | 01:39 AM
Tpsycho's Avatar
Cool sure beats flying off a jump and landing and having the handl bars snap off in your hands :0)
Old Jul 12, 2008 | 03:58 AM
ScottDaMan's Avatar
LOL phycho. Please please no helmet on that too? I want a picture of his face with handlebars not connected.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
