Rear bearing bad?
Old Jul 29, 2008 | 09:12 AM
Swaie's Avatar
Default Rear bearing bad?
Okay went out for a ride and decided to change my rear tires. I picked up on the axle and noticed that it had some play(one will would go up while the other went down. It pretty much wobbled back and forth. Do I need a new carrier or can I just tighten it up?
Old Jul 29, 2008 | 01:32 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
If it is wobbling and it is tight then your bearings and seals will be shot and need to be replaced. If it is loose then tighten it up until you loose the wobble and see how it feels as far as the bearings go just make sure that they are not binding up or grinding. Most likely the seals are shot becouse of the wobbling. I would plan on replacing bearings and seals to make sure everything is good.
Old Jul 29, 2008 | 01:35 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Yep, for sure, if your carrier bolts are a little loose it will wiggle all over, but if they're tight you need new bearings. Simple as that. Good luck!
Old Jul 29, 2008 | 01:40 PM
Swaie's Avatar
Cool I will check that. Thanks for the input guys
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
