baja ds650 tach on regular ds650
Old Aug 23, 2008 | 12:44 PM
yellowdemon23's Avatar
Default baja ds650 tach on regular ds650
The company I was talking about is Parker Yamaha just like "aceisback" said. I'll have to check out the other website.
Old Dec 13, 2012 | 12:06 AM
Paulie_Cicero's Avatar
From: In The Beautiful Northwoods Of Wisconsin.....Good Times, Good Trails, Good People !!
Yes You Can, I Have A 2000 DS-650. Been Trying To Hook Mine Up. I Tried To Hook It Up To The Coil Wire, And The Spark Plug Wire With No Luck. I Bought A Used Tachometer Out Of A Skidoo Snowmobile, Had The Rotax 600 Engine. The Green Wire Goes To Ground, And The Yellow (Signal Wire) Wire Hooks Up To One Of The Three Yellow Wires Located On The Left Side Of The Engine, Right Under The Gas Tank. I Think Those Are The Wires Are Coming From The Stater (Stator). Identified By The White Cylindrical Plastic Connector (Looks Like A Small Barrel). It Doesn't Matter Which Wire It Goes To. Just Be Sure To Connect It To Only ONE Of The Three Yellow Wires. And You Should Be Fine. If Your Looking For A Tach Like The One I Have In Mine, I Do Have An Extra One. If You'd Be Interested. My Email Is Heycuzzz@yahoo.com
Old Dec 15, 2012 | 11:25 PM
infantryvet's Avatar
ahhh wtf...
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Logan Collins
Sep 5, 2015 08:03 PM
