Do i need Shim unders?
Old Aug 22, 2008 | 10:15 PM
smbikes's Avatar
Default Do i need Shim unders?
I just got a set of web cams with 435 lift and 260 dur , but now i dont now wich way to go. Do i need a shim under kit or can i keep the stock shim over ? and can i just bolt them in or do i need to get different springs or what all do i need to use the cams ?
Justin
Old Aug 24, 2008 | 11:58 AM
SANDMAN430's Avatar
not positive but seems i recall something about 425 being the biggest you want to go with stock springs. call woods or web they will probably tell you what you want to know and if not call the bom.
Old Aug 25, 2008 | 11:11 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
You don't have too but its a piece of mind thing.
Old Aug 26, 2008 | 04:21 PM
ERBEDS650's Avatar
I would at least go with H/D springs, those cams should'nt go over 8000 RPM what CDI are you running?
Old Aug 27, 2008 | 02:16 PM
Boomer84's Avatar
Yes,you must change springs,because you will have coil-bind!
Old Aug 27, 2008 | 05:17 PM
smbikes's Avatar
i have a vortex cdi , so with shim unders i can go over 8000 rpm ?
Old Aug 27, 2008 | 05:54 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
The stock springs have .085 clearance.
Thus to stay within a .050 safe zone, you can only have a maximum lift of .425"
HD shim over should be fine.
Did you call Web and verify that the camshaft profile ramps do not clip onto the outside edges of valve buckets?
OMR
Old Aug 27, 2008 | 10:56 PM
smbikes's Avatar
OMR. i have no idea what u mean by *camshaft profile ramps do not clip onto the outside edges of valve buckets*
Old Aug 28, 2008 | 01:13 AM
OMR's Avatar
OMR
http://www.xtrememotorworks.com/cam_basics.htm
Old Aug 28, 2008 | 09:51 PM
AZSAND's Avatar
I DON'T KNOW MUCH AND I CAN TELL YOU CONTRARY TO WHAT BOOMER AND OMR ARE SAying i have run a pami 760 with degreed stage 2 cams without shim unders and stomped almost all comers(with the excetion of that dang jeffrivercity) but if i was building now days knowing what i know i would listen to boomer and omr and go for the safe bet!!!!!!!!!![img]i/expressions/face-icon-small-wink.gif[/img] MY PAMI NEVER RAN SHIM UNDERS UNTIL THE PREACHER REBUILT IT AND INSISTED I PUT SHIM UNDERS IN.
Alex G.
Sep 11, 2017 11:38 PM
Whitelx1
Oct 2, 2015 10:55 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
