Bombardier Traxter 500- Possible buy
I'm looking at a 1999 Bombardier Traxter 500 4x4 which is in pretty rough shape. The guy tells me it needs a coil, and I know it needs a seat. No doubt it needs all new bearings, brakes etc. too. I will do a compression test and so forth but what else should I be checking? What issues are usually apparent with this year traxter (1999)?
I'd check stuff like, does it have oil in it, is the carb leaking, shake the wheels to see if there is a lot of slack in the wheel bearings, if the plastics broke up, headlights/taillights work, make sure the VIN # isn't ground off, does he have a title, Is the rear-end/front-end leaking. And other general maintance stuff.
