Outlander 650 top speed
![Yup](https://atvconnection.com/forums/images/smilies/yup.gif)
I run 30" silverbacks on my 2011 800 max- the speedo is way off.
you'll need to clutch it to compensate for the larger tires.
but look at the bright side- your mileage will also be off- so the atv will show less mileage then what it actually is.
#15
no idea.
the speedo isn't accurate because of the tires.
probably somewhere in the low 50's if I had to guess.
but I really never had any of my atv's up at top speed (throttle pinned)
who buys a 4x4 atv for top-end speed?
![Huh](https://atvconnection.com/forums/images/smilies/huh.gif)
these big bore atvs might be capable of high speeds- but they were not designed to ride for any length of time at those high speeds, even with radial tires- they are not stable and will easily flip in a split second without much warning especially on tar.
#17
the brute 750 is a fast atv- will easily keep up with an outty in the trails if both riders are experienced. but at the end of the day the can-am rider will feel a lot better.
I've owned a couple of brute 750's, neither had the top end the can-am has.
brutes have a real strong bottom end and a decent pull in the mid range- but really start to wind out on their top end- can-am's pull strong from the bottom to the top.
but- how often are you gonna be drag racing brutes? if that's what you're really worried about just buy an outlander 1000.
#18
Anyone looking to go "top speed" but never go final speed because it causes unwise problem. So control your speed.
![Blahblah](https://atvconnection.com/forums/images/smilies/blahblah.gif)
#19
#20
