Cams
Old Jan 23, 2009 | 11:10 AM
  #21
McKay5858's Avatar
Default Cams
I know i don't have the money to have it profesionally ported, i'm just gonna clean it up a bit. I know if you go to crazy you can screw it up and make less power so i'll just clean up some casting marks and polish. Thanks for the offer though, that'll be the next step in a year or two.
Old Jan 23, 2009 | 12:02 PM
  #22
BBR650's Avatar
Is always changing bikes.
Default Cams
<div class="FTQUOTE"><begin quote>Originally posted by: THEBOM
Not that I know of.</end quote></div>
i watched your good ol buddy pennock change springs one day like this......i beleive it was on one of those great running 720's that were assembled
Old Jan 23, 2009 | 01:07 PM
  #23
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default Cams
Your guides are probably O K. Seats and valves ,check.
Your right, don't get wild . Just clean up casting flaws and maybe even bead blast the runners lightly.
Make sure to match up the intake to the head port when you doing it.
Old Jan 23, 2009 | 01:09 PM
  #24
THEBOM's Avatar
Default Cams
<div class="FTQUOTE"><begin quote>Originally posted by: BBR650
i watched your good ol buddy pennock change springs one day like this......i beleive it was on one of those great running 720's that were assembled </end quote></div>
That's another story. I have a couple he has work on now!!! OOOOWWEEEEEEE!!!!
Old Jan 26, 2009 | 07:12 PM
  #25
McKay5858's Avatar
Default Cams
what kind of bits should i use to clean up and polish this thing, what grit of sand paper to finish it?
Old Jan 26, 2009 | 10:56 PM
  #26
YAMASUXHONDUST's Avatar
Default Cams
MCKAY i used a tile bit for the dremel on the intake side of the head and the intake to ruffin up after i opened it up. if you need to get in the tight spots dremel has a cuttin wheel that looks like a little ball on the end this works well in the tight spots. as for my exhaust i just got rid of all the cast left overs with sanding disc paper i guess is what youd call it. homedepot has a dremel kit that has like 200pcs itll have everything you'll need except the tile bit. i hope this helps.lol
Old Feb 19, 2009 | 04:24 PM
  #27
McKay5858's Avatar
Default Cams
Just thought i'd let everyone know i got it all back together on tues night, fired it up but was to late to ride, last night took it for a quick rip, and LOVED it! It definately lost some rpm off the top but it is very very tourqy now, really good throttle response. Its kinda hard to tell the full benefits because the ground is still snow covered here and i just spin alot, can't wait for some dry ground to really feel the new power. Thanks for everyones help!
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
