Can ANYONE figure this out?!?!
Old Aug 6, 2010 | 12:31 PM
softap's Avatar
Arrow Can ANYONE figure this out?!?!
Hey guys,
I am just new to this Outlander thing. I have had a few ATVs, but it is my first Can Am.
It is a 2004 Outlander with the 400 ...... and I have a big problem!!
It now has starting and running problems ... it will not start normally.
It will ONLY start and run with the throttle Wide Open!
I took off the air filter, and gas is shooting out the intake while it is "barely" running. I am assuming this is because it is not running well at all. I have checked almost all the fuses that I can see ... and nothing!
Even if I put it in gear, it cannot get up enough RPMs to move this thing!
Please Help!!!!!!! I need my quad back!
Thanks!
Softap
Old Aug 6, 2010 | 12:38 PM
Boomer84's Avatar
Smile Maintance
Adjust your valves!!!!
Old Aug 6, 2010 | 01:04 PM
softap's Avatar
how do I do that???
Never done it before!
Old Aug 6, 2010 | 01:11 PM
yzryder125's Avatar
Take the head cover off of your engine, measure your valves to specification and add shims or take them out. It is an easy fix, most likely it will be your intake valves.
Good luck!
Old Aug 6, 2010 | 02:08 PM
softap's Avatar
do you know where I would find the specs??
Old Aug 6, 2010 | 02:20 PM
yzryder125's Avatar
This forum or if you giive me your atv year make model ect. i could find it for you or an owners manual
Old Aug 6, 2010 | 04:24 PM
justme23005's Avatar
Sounds more like a valve timing issue, rather than a valve clearance issue.
Old Aug 6, 2010 | 11:31 PM
softap's Avatar
Arrow
How would I adjust that timing/valve timing?????
It is a 2004 Outlander with a 400 ......
Old Aug 7, 2010 | 09:13 AM
This article explains it nicely. Valve Adjustment
wrencher82
Sep 28, 2015 10:02 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
