How to take warning labels off
Old Mar 12, 2001 | 06:30 PM
bomberds's Avatar
I was out trying to take the warning labels off my ds. They are glued on very good. I tried to peel them by hand and they didnt want to come off. Some of the stickers are too close to the graphics to pressure wash them off. Whats the best way to take them off. Thanks
Old Mar 12, 2001 | 07:28 PM
CALDS650's Avatar
Try a heat gun or use a razor blade to lift the lables.
Old Mar 12, 2001 | 08:44 PM
ScoobyDFW's Avatar
There is also a product called sticker-off. Opposite of sticker-on.
Quicksand's Avatar
Sadly the only thing that I've found to remove those damn labels is patience! They suck pure and simple. The way I've done it is a blow drier (don't have a heat gun) and a rasor blade. The problem is that you'll most likely scratch the bajezus out of the plastic if you're not careful. I've got a couple more I'm still going to remove and I'm going to use the Easy Off method of masking the area around the sticker and spraying the oven cleaner on the sticker. I've done this on car/truck windows and it works like a champ! Just need to be careful the amount of time you leave it on.
Old Mar 12, 2001 | 10:19 PM
Jimmie's Avatar
i used a product called desolve it's similar to goo gone an orange based substance, i had to remove all my stickers to put the alba kit on.
Old Mar 12, 2001 | 11:10 PM
BombBan's Avatar
use a blowdryer that people use on there hair. It takes a while but it is effective.
Old Mar 13, 2001 | 03:14 AM
BlackHawk's Avatar
On my LT250R I used a blow dryer (the higher heat the better like 1500w or better) to heat them up and remove them. It was rather simple, didn't leave any marks, and most of the stickers came off whole. If you're having trouble, heat them up longer or more. The idea is to get the glue holding the sticker very hot so that it will release easier. I generally found it became very hot to touch when it was working best. I never had the need for anything but a blow dryer, and maybe some sort of blade or similar to get them started. If you start to cook your fingers, try pliars to pull at the sticker with. Once hot and you have a good hold just go slow and keep it hot! (Are we still talking about stickers here?!?!)
Old Mar 13, 2001 | 11:54 AM
killerb's Avatar
i used the same thing as jimmie.rubbed it on,let it set 4 10 min.they pulled right off in one piece.
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
