RIMS
Old Apr 18, 2001 | 09:07 PM
DSWOLF's Avatar
DO YOU THINK THAT THE DS RIMS ARE TO SOFT
2000 DS
ALBA PIPE AN SILENCER
ALBA MAIN JET
K&N AIR FILTER AN PREFILTER
SUPPERTRAPP SPARKS ARRESTER
CUSTOM FENDER BRACES
Old Apr 18, 2001 | 09:29 PM
DSjockey's Avatar
I think the Kenda tires are soft
Old Apr 18, 2001 | 10:18 PM
Knutz's Avatar
I think DSJockey has it right, the kenda tires don't protect the rims the way a better tire does. We just don't feel all the rocks that some of us[me included] hit because the suspention absorbs the hit. 3TV just seems to do a better job of avoiding the rocks than most of us.
Old Apr 19, 2001 | 04:13 AM
BlackHawk's Avatar
No, Douglas .190 (Red Label) rims are good quality for average riding. For me, I hit A LOT of rocks on my first outing, in fact within the first 2 hours of riding I had dented two of my rims notably. I recently purchased a set of (4) Douglas .190 Red Label Rims with re-enforcing rins installed by OMF, as well as 22/23" Holeshot XCT tires. These re-enforced rims and larger tires should be all I ever need to keep any and all rocks from harming my rims.
If you have the finances to buy them, they look awesome as well as perform a function.
Old Apr 20, 2001 | 10:40 PM
chop's Avatar
how much were the rims with the rings?are the rings in and outside or just the outside?
Old Apr 21, 2001 | 03:29 AM
BlackHawk's Avatar
The douglas .190 Rims with inner and outer rings were $94.99 and 99.99 each. I believe the rears were 94.99 since they are a 9" and the front are 10".
You can order them with only the outer rings if you want, they cost about $25 less. You can also buy rings to weld into your stock rims as well. I would recommend anyone get the rims with inner and outer rings, they should hold up to most anything (and look awesome!)
I paid about $700 total for 4 rims with inner and outer rings and 4 Holeshot XCTs all mounted.
If you run the front 10" rims with inner rings, you'll have to either remove your front fenders, or with only a slight modification to your mounting brackets on the fenders you can keep them and run the rings. Currently I am running with no fenders, but I plan to modify the fender brackets so they will fit with the rings installed, so that I can ride with or without them, whatever I choose.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
