Clutch assembly, Handlebars, and a Helmet.......
Old 06-18-2002, 09:46 PM
ThePunisher's Avatar
Ok, never mind I found it!
Old 06-19-2002, 02:55 AM
Puttnutt's Avatar
Trail Tech has just released there 1 1/8 bar and clamp for the DS. They are working on a bar clamp which also houses there computer, they tell me it should be available in a couple months. Rich A
Old 06-19-2002, 10:13 AM
Rockey's Avatar
So will this clutch lever assembly make the clutch fell like stock once you upgrade to heavy duty clutch springs? I want to upgrade to HD springs eventually but I'm not looking forward to heavier clutch feel.
Old 06-19-2002, 12:20 PM
MadBaja819's Avatar
Whatever the stock clutch feel is with the HD springs, the lever will make it 3.25 times easier.
  #15
Old 06-19-2002, 12:42 PM
AdamsBadDS650's Avatar
I just realized something. There is a wire connector that hooks into the stock Clutch perch, I'm guessing it is for the start-in-gear feature, with the clutch pulled in. With the new Clutch assembly, You will have to disconnecr this wire, I'm guessing. With the ner lever and Perch, will you only be able to start in neutral?
  #16
Old 06-19-2002, 12:44 PM
Oh, and I went out, and was messin with the stock clutch, and realized that you have to pull it all the way to the bars anyways, or at least you do on mine.
  #17
Old 06-19-2002, 12:49 PM
DemonDS's Avatar
Maybe you could try diconnecting the stock clutch wire and see if it will let you start in neutral, that way you woud know. Lt us no too hehehehe
  #18
Old 06-19-2002, 01:22 PM
Ok, I went outside, ands disconnected the wire, like DemonDS suggested, and with the wire disconnected, it will start in any gear, with, or without the clutch pulled in.
EIF
04-20-2017 07:15 PM
buddieboy
12-09-2016 05:50 PM
tysonbully
09-28-2015 02:30 AM
jbrewster94
09-23-2015 04:16 PM
roy.hawkins3@gmail.com
09-11-2015 02:35 PM
Quick Reply: Clutch assembly, Handlebars, and a Helmet.......
