Whats the differance in DOT3 & DOT4 brake fluid?
Dot 4 is a higher quality,it has a higher boiling point,therefore a better operation range than Dot 3,you can top off with the 4,but it wouldn't take much to just bleed out and refill with the Dot 4,so if you have time,go ahead. I have been using Valvoline synthetic brake fluid,it is rated Dot 5,and it is compatible with 3 and 4.
Stirling
08-09-2015 02:49 PM
