Got it jetted. Now I need some advice!
Old Jun 25, 2002 | 11:26 PM
02BAJA's Avatar
I have my jetted and it started right up without a problem. Idle is good. I took it for a ride and in 2nd gear going up a hill, it just pops and cracks until I let off the throttle. I read the trouble shooting and adjusted the needle down to see if it helps. I started on the third notch and am on the first now. Still the same symptoms. I took hightowers advice from other threads and messed with the mixture screw. Turned it till it bogged both ways and went in the middle. I am running a 190 jet. I have a WB slip on and a K&N filter. Maybe need to go a jet size down? Any insight to this newbie will be appreciated. Thanks.
Old Jun 25, 2002 | 11:54 PM
buttfungus's Avatar
The needle goes in on top of the carb. The main jet is the one inside the perforated tube tube. The needle slides through the main jet from the top of the carb if that helps any. I have a diagram of the carb pic
Old Jun 26, 2002 | 09:45 AM
clif's Avatar
You might also check and make sure you have not pinched the small air hose that runs along the frame,where the seat hooks et the front.
Old Jun 26, 2002 | 01:01 PM
Hightower's Avatar
More than likely, the main jet you're using is too rich. Hard stumbles like that are from richness (providing no mistakes were made and everyhting is back together right, with no pinched off tank breather). I use the 195 main and I'm lid-free, and my Yoshimura pipe really flows mega air too. I'm pulling so much air this way I had to go up to the 195, but if I was to put the airbox lid back on, the bike would not run under load - even on flat ground.
One quick check, before rejetting, is take the lid off and go for a run. If the stumble is gone, you were just too rich, but if its still there then something is wrong somewhere.
If you wanna run lid-free, follow stage 3 instructions in the kit, if you wanna keep the lid, follow stage 1. I would say the 180 main will probably be about right if you keep the lid.
The idle mixture screw controls fuel/air ratio at idle only, and causes popping after letting off the throttle if its set wrong. After you get your main jet and needle set right, re-adjsut the idle mixture again.
Old Jun 26, 2002 | 02:00 PM
02BAJA's Avatar
Thanks for the replies. I will try running without the lid tonight and check things over one more time. I will re-post if there is still a problem.
Old Jun 26, 2002 | 02:29 PM
TheFasterTheBetter's Avatar
Put your needle back to the third notch. You are going to end up fighting too many things.
Did you see the article in Dirt Wheels on jetting from a couple months back?
The air box idea is a good one. I take my air box lid off when I go to Sand Mt. and sometimes put it on when back home. That air box lid probably works the same as 1/2 of a jet size or about 2000' elevation. IMO
Old Jun 26, 2002 | 09:33 PM
AdamsBadDS650's Avatar
Hey, can someone tell me how to get the needle out of the slide on the stock carborator? I need to change my clip position, and I can't get it out. Also, what is the air mixture screw set at, in stock form, and where is it?
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
