Oil tank drain plug
Old Jul 8, 2002 | 08:54 PM
Sandaholic's Avatar
I was on Jegs (auto parts) web page and saw this Fram Sure Drain Oil Change System. Here is the link
I would think something like that would work really well in making oil changes a whole lot cleaner.
Anyone know what size the oil drain bolt on the oil tank?
Old Jul 8, 2002 | 10:14 PM
01ds650's Avatar
Someone else did that. I was going to, went out & bought one & then noticed how strong the magnet on the stock drain plug is. I felt better having a magnet on the drain because of the wet clutch & all. I ended up just putting the Fram thing on my truck [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 8, 2002 | 10:16 PM
Hightower's Avatar
3/8"NPT is the size of the drain hole threads on the tank, not sure about the crankcase drain. NPT being National Pipe Thread - standard fittings at any hardware store.
I put a heat resistance teflon sealed chrome plated brass ball valve - 1/4"NPT threaded into a brass 3/8":1/4" reducer bushing inplace of the tank drain plug, and removed the handle. WHen I change oil, I screw a plastic hose barb with 2' of clear hose into the valve finger tight, and open with a wrench. When riding, I keep a plastic plug in the valve finger tight.
Old Jul 9, 2002 | 08:32 PM
crashnburn's Avatar
That is exactly what I did. You do lose the magnet from the plug, but the oil changes are a breeze now.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
SDR-II
Sep 29, 2015 01:06 AM
Shifts
Jul 3, 2015 07:59 AM
