gearing calculator
Old Oct 17, 2002 | 08:41 PM
ScoobyDFW's Avatar
Default gearing calculator
Eaglecollector, Does your calculator use DS650 internal gearing or F650 internal gearing, they are different
Old Oct 17, 2002 | 09:32 PM
Eaglecollector's Avatar
I used the same data that Markynark has in his calculator. He has said that it was for the f650 and modified for the DS650. I was not able to find any gear ratios to confirm this. My shop manual does not give this information. Nor can I find it on the bombardier site. :-(. I have no reason to doubt what Marky has said though. He seems to know his stuff. :-)
Old Oct 17, 2002 | 10:35 PM
ScoobyDFW's Avatar
The gear ratios you have used are the F650 gear ratios. The primary reduction ratio you used is modified from the F650, to approximate the DS650 gearing.
The F650 Gearing is:
2.75
1.75
1.31
1.05
0.88
w/primary reduction ratio 1.946
I was told the F650 has a 29% longer primary ratio than the DS, which would put the DS primary ratio around 2.51.
I was also told that the F650 5th gear is 9% longer than the DS, which would put the DS 5th gear ratio around 0.95.
I had the whole motor apart but never counted the teeth on all the gears. Someone must have by now. I'd like to get confirmation on the numbers.
Old Oct 18, 2002 | 08:04 PM
ScoobyDFW,
Thanks for the heads up. I will do some more checking arournd and see if I can get the real numbers. When I do, And soon I hope. I'll let ya know what I found out.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
