Barnett Clutch Springs??
Old Oct 28, 2002 | 11:41 PM
Ds650RaCeR's Avatar
Default Barnett Clutch Springs??
[img]i/expressions/face-icon-small-happy.gif[/img] ill tell you on msn later domi!
Old Oct 28, 2002 | 11:49 PM
650MANIAC's Avatar
Tate, when your clutch started slipping the first time all you did was change the springs and not the clutch plates. The plates was probably burned pretty bad by then and the springs was just a temporary fix. I would change the clutch plates and keep on going.
Old Oct 29, 2002 | 12:03 AM
Ds650RaCeR's Avatar
where can i get all of this???
Old Oct 29, 2002 | 12:12 AM
650MANIAC's Avatar
Shane has the clutches in stock. They are between $70.00 and $80.00 I think.
If you want the Barnett clutch kit he can also get it also.
Randy
P.S if you want the Barnett springs I have a set that I have never used that came with my kit.
Old Oct 29, 2002 | 12:15 AM
  #15
Ds650RaCeR's Avatar
how much for the springs?can you help install the plates and springs because i think im going to try to get some cams to and you said you would put those in.
Tate
Old Oct 29, 2002 | 12:17 AM
  #16
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
I just run the stock clutchs and steels. I run the Pami springs in one bike and the TVI in anouther. No problems with eather. Call Gary he'll wheel and deal.
J Ross
Old Oct 29, 2002 | 12:20 AM
  #17
650MANIAC's Avatar
When you get all your stuff together give me a call and I will put it all in for you. We will work something out on the price and you wont be let down.
Old Oct 29, 2002 | 12:25 AM
  #18
Hightower's Avatar
My clutch slipped like crazy after adding some HP, so I got the RWR springs - motor only had 50 hours at the time I took it apart to install, and only half of that was with a slipping clutch. I measured the fiber disks while I had it opened up, and discovered that the 25 hours of slipping totally wore them to the bottom of the tolerance outlined in the shop manual. I replaced the fiber disks and put the RWR springs in, and now 35 hours later I still have no slipping - all is well, and I'm a speed shifter in the drags too. Since I have no slipping, I would assume that my new disks will last much longer - time will tell.
  #19
Ds650RaCeR's Avatar
thanks well i have to get the money first im looking for a afterschool job right now but its hard to find one considering im 15 but when i do i will give you a call...oh yea i may as well get you to put me on ALKY!do you think me and brandon would be a good race if i had the piston and cams???
Tate
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
