im getting a 15 tooth sprocket. Do i have to get new chain?
Im getting a 15 tooth in the front because im getting 23 tires iin front and 22 in back so im goign to get a 15 tooth in the front. if i do this do i need a new chain? and also what is the stock sprockets at for front and back because i have no clue. i need to get a manual.
thnaks
thnaks
Thanks JEFFROE![img]i/expressions/face-icon-small-happy.gif[/img]
It's my understanding that with the taller rear wheels to which you're referring, it has the same effect as gearing up, i.e., smaller rear sprocket/larger countersprocket. Is this correct?
I'm trying to gear down because I ride exclusively in the sand. I have 20 inch paddles in the rear and I want to get more brute hillclimbing power out of my Baja. My plan is to go with the 15/42 set-up. Does that sound right to you? I'm not at all concerned with the loss of top-end. Thanks again for your help!
