Replacing the steering stem (How Hard?)
Old Sep 3, 2003 | 12:20 PM
bigben's Avatar
Default Replacing the steering stem (How Hard?)
Johnnyairtime-- Doesn't the oil tank share two mounting bolts with the gas tank and cover? I had mine all apart in May but don't remember what all it involved.
Bigbaja-- I'd use joshiepoo's idea and get a machine shop to fix your stem. I did mine myself and it turned out pretty good, I think. Plus the wait for a machine shop to do it should be minimal.
Old Sep 3, 2003 | 12:37 PM
Johnnyairtime's Avatar
Bigben,
The oil tank has it's own mounting. Two bolts up at each top side... and one down low. My gas tank is an IMS... so I don't remember the stock tank and if it mounted there or not. The IMS only uses two bolts on the rear with a lip that catches under the frame in the front.
I've got most everything apart. However I didn't completely remove the bar controls from the bars. Nor did I completely remove the dash and wiring. I'm going to do that now. I also have a custom mount for my HID light in front of the oil tank... so removing or moving the oil tank is a pain in da ****. But I'm going to get out my 10mm again and start moving all kinds of stuff. I think the more I remove the better.... however I feel the new stem may be even harder to put in so I might as well take it all apart now. I hope I never bend a stem again! This is worse than pulling a motor to me.
Old Sep 3, 2003 | 08:57 PM
Eaglecollector's Avatar
What stem did you buy? was it an extended one or stock length? As you can see in my sig i got the + 1 1/4. Now my bar height is perfert for me. Amazing how such a small amount can make such a big diff.
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
ghost civic
Jul 19, 2015 10:13 AM
1966F100
Jul 12, 2015 03:01 AM
Scottma518
Jul 10, 2015 12:42 AM
