HELP!! Hub nut removal
I got mine off like this:
Somebody sit on the quad in gear and apply the rear brake. use a socket on a breaker bar with a pipe for leverage and brake it loose. Being in gear combined with the brake will hold it well enough. Do the same to retorque, and torque it proper 170-180ft.lbs. Don't forget to regrease the spline, and replace the cotter.
