How does the RWR cams compare to the PAMI cams??
Old Mar 20, 2003 | 07:33 PM
  #21
Birdoprey's Avatar
Default How does the RWR cams compare to the PAMI cams??
Hey DSMike,
What cams are you running?
Old Mar 20, 2003 | 11:21 PM
  #22
dsmike's Avatar
right now i have to A-2 RWR cams. do NOT try to do this if your not smart with motor or cam timing!
Old Mar 20, 2003 | 11:29 PM
  #23
Birdoprey's Avatar
Heh! Don't worry, i'm not reving my baby that high! Just wondering what cams/cam timming(specs) pull that high up....
Old Mar 20, 2003 | 11:48 PM
  #24
dsmike's Avatar
i use some weird cam timing, the A-2 cams are exhaust. so i have 2 exhaust cams in my bike right now. i broke my other cam and had this one so i did some welding on it.(LOL)
Old Mar 21, 2003 | 12:16 AM
  #25
Hightower's Avatar
FYI on specs e-mailed from Gotfried:
1. sport cams - 266 degree - 10,00mm lift (.394")
2. "Pami EX" - 276 degree - 10,90mm lift (.429")
3. "599" IN - 284 degree - 11,00mm lift (.433")
4. "Pami IN" - 292 degree - 12,50mm lift (.492")
5. Stock cams -240 degree - 9,70mm lift (.382")
Specs stamped on my RWR cams (finally found them, under the sprockets!)
RW A1 - 284deg./.406" lift
RW A2 - 276deg./.433" lift
Web:
284deg./.395"
287deg./.425"
http://www.webcaminc.net/bombardier-atv.html
Old Mar 21, 2003 | 11:31 AM
  #26
JEFFROE's Avatar
is there a high lift cam out there that won't require shim under bucket. currently i have the A1 rwr. really don't want to pull off my head because of fussy gasket on the pami motors, to go with shim unders.
Old Mar 21, 2003 | 11:49 AM
  #27
SANDMAN430's Avatar
i talked to elliotte yesterday i believe he said it is the #7 and it is a 450-290, said SHOULD clear with there stuff, dsmike probably has or has run them. anyways with there set-up they run shims on top
Old Mar 21, 2003 | 04:00 PM
  #28
ThePunisher's Avatar
The only reason anyone is running shim under bucket is because of a post a long time ago form Marky Nark. Marky chewed up his motor when his regulars shim on top popped out and droped into his engine case and did some damage. That doesn't mean that it happens to everybody but it is always better to be safe than sorry.
Old Mar 21, 2003 | 08:11 PM
  #29
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Yes i argree people say springbind ????????? i run the pami race with no shim under buckets and i do belive the shim underbucket is a runaway myth!! go ahead guy's smack me if you will but i thjink there waste of time and money!! [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 21, 2003 | 10:51 PM
  #30
dsmike's Avatar
i have the #7 cams in my yellow bike. i don't have shims under the buckets. haven't had any trouble with them.
badgerboy1
Sep 26, 2017 06:11 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Hack714
Sep 26, 2015 08:11 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
