Need help FAST!
Old Apr 10, 2003 | 12:02 PM
bombrider's Avatar
Default Need help FAST!
I went to drain the oil out of my engine, so i open the drain plug on the bottom of the engine and their is no gasket, although the manual tells you to change it, so is there supose to be a gasket or not? and if there is do i realy need it?
thanks for any help (this is the first time i change my oil by the way).
Old Apr 10, 2003 | 12:05 PM
SANDMAN430's Avatar
there is but it, only lets oil seep out like if you leave it in one spot it will have a spot on the floor. seems it says to replace every other oil change.
Old Apr 10, 2003 | 12:08 PM
bombrider's Avatar
Ya but i cant find it, so what im asking is do i realy need it?
thanks
Old Apr 10, 2003 | 12:14 PM
dsguru's Avatar
Bombrider the is a aluminum washer that goes on the drain plug that is what they call the gasket.If you don't see it on the drain plug it could be stuck on the block.If not it is at the bottom of your used oil.They can be used over if you don't have a new one.Some cars use the same one you could try a automotive jobber.
Old Apr 10, 2003 | 12:22 PM
bombrider's Avatar
But thats the problem, i cant find it enywhere
Old Apr 10, 2003 | 12:28 PM
DirtDemond's Avatar
There is a gasket there for a reason. they wouldn't put one there if they didn't need it. so go buy a knew one. it will not hurt your engine unless your leaking oil. just keep an eye on your oil level. and i bet you could pick up a alum. washer at your local hardware store.
Old Apr 10, 2003 | 12:31 PM
SANDMAN430's Avatar
must of lost it on another oil change, and didn't notice, there is a problem with the cases gettin stripped if you over tighten the drain plug so i would make sure i got one i think they are a dollar here, so it couldn't be much there if it is i'll mail you one.
Old Apr 10, 2003 | 12:39 PM
bombrider's Avatar
Ok, thanks alot you guys!
Old Apr 10, 2003 | 12:55 PM
CrazyWhiteDude's Avatar
I did an oil change and forgot to put the aluminum washer gasket on. I had no problems with any leaking, but the next time I put the same one back on and still have no problem with using the same one over. Don't worry about it but you should get one eventually.
Old Apr 10, 2003 | 12:57 PM
bombrider's Avatar
Thanks, but i think i'l jast wait til tomorow and go get me one, thanks anyway
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
