kazuma 110 falcon problems(Help)
Old Apr 26, 2006 | 06:58 AM
mud91's Avatar
Default kazuma 110 falcon problems
I have a 110 falcon that I cannot get in started, bought from a guy said it ran when he parked it. So far I have gas to the carb(cleaned it) spark to the plug. Just turns over but no start. I'm thinking its electrical. any suggestions where to look.
Old Apr 26, 2006 | 08:14 AM
mconner's Avatar
Default kazuma 110 falcon problems(Help)
when you say cleaned carb you mean you removed pilot and main and cleaned them right - if so I would check valves clearence - I don't think it's electrical if you have spark
Old Apr 26, 2006 | 08:16 AM
mconner's Avatar
forgot - I would drain fuel and get new gas. might of been sitting a while
Old Apr 26, 2006 | 11:30 AM
mud91's Avatar
yea I've cleaned the carbs the good, took all the jets apart blew everthing out, The gas is good. Now about the valves, how much clearance do I need? I own a couple of banshee's so I'm not used to the valves..but if someone could tell me how the check them. I'll try that this evening. thanks
Old Apr 27, 2006 | 07:41 AM
mconner's Avatar
I don't have a 110 but maybe someone here could help with clearance specs. If not try raceway , redcatmotors, ect . tech info is hard to get from dealers .The inspection process is the same for all 4 strokes , do a search on the other forums yamaha honda.you will just have to find inspection plugs on your quad and specific clearences.
Old Apr 27, 2006 | 10:22 AM
mud91's Avatar
just need a little run down on how to adjust them, I don't think its the valves but I'd like to get them out of the way while I trouble shoot.
Old Apr 30, 2006 | 07:28 AM
mconner's Avatar
any progress yet ? here's a pretty good valve explanation (http://www.motorcycle.com/mo/mcdirt/.../toolbox2.html).
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
