Can't Shift from F to R when engine running
Old Aug 26, 2006 | 02:54 PM
notcotten's Avatar
Default Can't Shift from F to R when engine running
After sitting for a few months, we got my Redcat 150 started today and I was about to hit the woods when I discovered that I could not shift from Forward to Reverse or Reverse to Forward when the engine is running. It shifts fairly easily when the engin is turned off. Any ideas on what is causing this and is there any adjustment I can make to correct it.
Thanks!
Tanman
Old Aug 26, 2006 | 08:18 PM
RacewayATV's Avatar
I would have to guess that a gear chipped in the reverse trans. You would have to drain the gear oil, pull off the front sprocket and take the trans cover off to see what things look like in there. It is not hard to do at all. There is 3 gears in there! I would bet one chipped and you will need to replace it. We do also carry the gears. Hope this helps!
Raceway ATV !
Old Aug 27, 2006 | 08:52 AM
billl2099's Avatar
what happened to one of ours is a nut came loose on the leakage at the revese gear box, did the same thing,
Old Aug 27, 2006 | 09:24 AM
notcotten's Avatar
Bill,
Thanks for your reply. Can you describe where I should look to see if this nut came loose? Is it external or internal to the reverse gear box? What does the reverse gear box look like? Is it the box that the mechanism moves the shaft in an out when shifting from forward to reverse and vice versa?
Old Aug 27, 2006 | 07:29 PM
billl2099's Avatar
it was a external nut,down on the shaft that slides back an force on top of the reverse gear box , mine was loose not leting full stroke to engage the reverse gear or if it was in reverse then won't let it engage in forward gear, i added a lock washer and loctite, simple fix but took me awhile to locate the problem
Old Aug 27, 2006 | 07:35 PM
billl2099's Avatar
just check all the nuts on the leakage and if you need a picture pm me your e-mail address and i'll sent you one
Old Aug 27, 2006 | 09:21 PM
notcotten's Avatar
Thanks, I'll check all the joints in the linkage and make sure the nuts are all tight.
Old Sep 11, 2006 | 03:45 PM
AFROracing's Avatar
does the idle seem higher than normal, you may idle it down as much as possible. I know my polaris does the same if it's idle is to high!
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
scaldwellk
Jun 19, 2015 05:08 PM
brinkkl2000
Jun 11, 2015 12:46 PM
Jiggypete
May 30, 2015 07:55 AM
