performence???
Old May 29, 2007 | 04:20 PM
  #41
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default performence???
That sounds like a great plan jetmotoracer!! [img]i/expressions/face-icon-small-cool.gif[/img]
Old May 29, 2007 | 04:27 PM
  #42
jetmotoracer's Avatar
i just called and they are sending me a new sproket jets and shock....i dont remember if i said i want a 15 tooth FRONT sproket i hope they have the commen scence to geuse that.........they shoul be here in a few days....how do i install the jets????........ race way is the best!!!!!!!!!!
Old May 29, 2007 | 04:30 PM
  #43
pimpsmurf's Avatar
They know what they are doing over at Raceway. When you get the jets in and your ready to install them, we will guide you through it. It is really easy to do, and you should only need a socket set and maybe a screw driver.
-JNY
Old May 29, 2007 | 04:34 PM
  #44
could i mess my engin up if its done wrong???????? and what would i have to take out i think i heard something about an over flow tinng or something...idk ill post when i get them
Old May 29, 2007 | 04:53 PM
  #45
with the new sproket will i be able to go full throttle in 5 th gear ?/?/?/?/?/?/?/?/
Old May 29, 2007 | 05:30 PM
  #46
pimpsmurf's Avatar
Don't double post. Use the edit button if you want to say something else after you do a post.
All you have to do is open the carb and screw the new jets in place of the old ones. It is very easy to do. I think there are 5-6 bolts to remove. It should not take more than 10 minutes and you would have to really try hard to mess anything up. Don't worry about it now. It will be easy when you get the jets.
You will probably be able to go above 1/2 of the engine's rpms in 4th gear (which is the highest gear) with a 15 tooth sprocket.
-JNY
Old May 29, 2007 | 05:34 PM
  #47
but it has 5 gears???? how is that posibal ... and i forgot you could do that
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
