how to un-hook the rev limiter
Old Sep 3, 2007 | 04:13 PM
jetmotoracer's Avatar
Default how to un-hook the rev limiter
to un hook the rev-limiter all i have to do is un hook theC.I.D right ? witch is the little black box by the gas tank correct, by the way i would want to un hook it when im pinning the throttle because i have a 15 tooth front sproket and i was told that it would blow upo if it hit it...... and if i do un plug it till i stop and re plug it what is the consaquences of unpluging it ?????
Old Sep 3, 2007 | 08:03 PM
billl2099's Avatar
if you unplug the cdi your atc not going to run, its the brain of your ignation system
Old Sep 3, 2007 | 08:08 PM
o so is the rev- limiter internal ?????
Old Sep 4, 2007 | 10:22 AM
billl2099's Avatar
the only way to remove the rev limiter is to replace the cdi unit with a after market one that doesn't have one.
Old Sep 4, 2007 | 10:58 AM
ooooo... i thought because there was 2 wires on it that one was the revlimiter..... and the other was the ignishin
Old Sep 4, 2007 | 05:59 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
<div class="FTQUOTE"><begin quote>Originally posted by: jetmotoracer
I would want to un hook it when im pinning the throttle because i have a 15 tooth front sprocket and i was told that it would blow upo if it hit it....</end quote></div>
The rev limiter will keep you from blowing up the engine. You could ride along bouncing off the rev limiter if you wanted to. You would blow up the engine if you removed the rev limiter.
Old Sep 4, 2007 | 09:55 PM
hoytultratec's Avatar
like mywifesqaud says you will blow up the motor the gain you will get will not be enough to take a chance smoking the motor, be happy with the speed your getting and start saving your money for a used honda 300ex or something then you can go fast.
hoyt
Old Sep 5, 2007 | 06:42 PM
no ill be going to a 400ex for my next quad[img]i/expressions/face-icon-small-happy.gif[/img].......
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
