help with rear axle leak
Old May 11, 2009 | 09:16 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
oren213 , I pulled the left side of my Jetmoto 150s rear end apart yesterday... It looks just like yours..It was fairly easy...pull the left tire/hub off. clean around the seal/axle tube area.. then pull the tube off the axle. On mine the axle tube is the inner "race" for the seal. The seal should come out easily if you pry it out with a long thin screwdriver. Mine also had a o-ring on the inside of the axle tube..mine was leaking and letting a little fluid out of the end of the tube where it butts up against the hub. Always wondered where that came from.
Old May 13, 2009 | 01:12 PM
GNXGuy's Avatar
It's leaking because its overfilled.
I have a jetmoto 150 with rear reverse built into it.
That is what the problem was with mine.
Old May 20, 2009 | 03:34 PM
KTM Patrol
Former Chinese POW!
How much fluid do you put in your 150 GNXGuy?
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Rider252
Jul 6, 2015 03:37 PM
