New china atv.
Old 06-25-2009 | 09:26 PM
TriplxX07's Avatar
Default New china atv.
Not sure of the brand,but it's a 125g... 125cc sport atv.. Just picked it up last Tuesday.. I have a questions though... When I was putting it together, and it was still sorta in the crate.. Basically jacking the front up, and then the rear to assemble it.. Was working alone... I noticed that all the castle nuts in the front suspension where loose.. The cotter pin was installed etc.. Was just wondering if I need to install washers so I can tighten them, or is that normal for them to be loose like that??? Also does anybody know the ngk plug that would take??? Finally i noticed for the rear chain adjustment.. The bolts go through the bracket for the chain adjustment.. And both nuts are stacked togther on the outter side of the bracket.. I thought one nut should be on the inside of the bracket, and the other on the outside to adjust the chain????
Old 06-25-2009 | 10:24 PM
outofline's Avatar
Do put another washer on the castle nuts to aline the grove and hole better or they will alwys be sloppy (you can see on my web site where I did this to my Jets also). The two nuts on the outer side of the axle is correct, one is there to lock the first from coming lose!
Old 06-26-2009 | 06:51 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Ngk c7hsa
Old 06-26-2009 | 09:12 AM
TLC's Avatar
TLC
Pour the lock tite to anything you put together, some people take apart what has arrived already together to add lock tite.
bigred20653
10-02-2015 10:05 AM
Lucas Bohanan
09-29-2015 01:16 AM
tysonbully
09-28-2015 02:30 AM
01ssls1
09-22-2015 06:50 AM
awer1968
09-08-2015 11:02 AM
Quick Reply: New china atv.
