110CC no power
Old Jan 16, 2015 | 01:17 PM
bdelancy's Avatar
Default 110CC no power
so i have a 110 cc i replaced the solenoid that was clicking well the new one did the same thing my battery test out fine and fully charged and not long after the insulation of the new solenoid it starts buzzing then i loose all power and the battery charger will shut itself of i get nothing if i cross over the terminals on the solenoid. any thing will help at this point thanks in advance
Old Jan 17, 2015 | 05:30 AM
If the solenoid was buzzing, the battery is almost flat or the starter has shorted out or something has seized. First check if the engine moves freely as it could be seized, if that is OK, either strip the starter to find the fault or get a new starter.
Old Jan 17, 2015 | 10:39 AM
bdelancy's Avatar
the engine turns over but the starter drags then just the solenoid buzzes it will only turn over when everything is cold its like after you turn it over the first time its done until it sits a while
Old Jan 17, 2015 | 02:30 PM
colt77's Avatar
buying chinese crap? this trouble is your punisment. and more coming. son, find a nearest junk/ scrap yard....
Old Jan 18, 2015 | 04:15 AM
That sounds a lot like a dud battery. Did you test it under load?
Old Jan 19, 2015 | 06:49 AM
bdelancy's Avatar
merryman i have tried two different batteries they work fine in other bikes. i have also tried a different starter i still get the same results.
Old Jan 20, 2015 | 04:09 AM
Then your engine must be seized, have you taken the plug out? If the float sticks, the cylinder can fill with fuel on some models and, if you are trying to compress fuel, the engine won't go over compression.
The other possibility is a bad wire from the battery to earth on engine or frame, or from battery to solenoid or solenoid to starter.
Old Jan 20, 2015 | 08:49 AM
bdelancy's Avatar
i got it to start last night by jumping it off my truck ran great at idle as i increased the throttle it started popping so i took the carb off and cleaned it up then put it back on the cables it clicked and lost all power im showing amprage on the battery and solenoid but nothing past that
Old Jan 20, 2015 | 10:54 AM
MPDano's Avatar
Double posting is no bueno in order to keep Forums clean and followable.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
