2017 Tao 125D Starting Problems
We purchase the 125D in December and now it's having issues starting. We've replaced the spark plug, coil, stator and cdi box, even the fuse and still can't get it to start. It's getting a very weak spark but that's all. It went from running one minute, turned it off and now it won't start. It acts as if it's going to but nothing. We've had suggestions to bypass the alarm, but we're not sure where to do that at. Any help would be greatly appreciated. Thanks in advance!
Go through and check your grounds as well as cycle your kill switch and key a few times. Moisture may have built up causing a bad connection. You are still under warranty so im hoping the place you bought from is supplying the parts. Also did you drain the shipping oil out and refill?
DumbDad
1) Engine problems..
13
Jun 21, 2021 02:18 AM
Stanb999
Dec 23, 2010 11:23 AM
