SunL SLA-135
Old Jun 14, 2018 | 04:26 AM
  #21
HackStorm's Avatar
Awesome - thanks again for all your help! Very much appreciated.
Old Jun 14, 2018 | 08:16 PM
  #22
HackStorm's Avatar
Merryman - can you or another helpful member please help me locate a complete wiring harness for a 2007 SunL SLA-135. Thanks
Old Jun 15, 2018 | 01:44 AM
  #23
If it starts, and runs, and charges the battery, leave the wiring alone. It looks like the original harness is no longer available, and those "universal" harnesses cause a whole heap of trouble. Unless you are an electrician, you will be lucky to get one to fit properly.
Old Jun 15, 2018 | 04:12 AM
  #24
HackStorm's Avatar
Now its back to the original problem of hitting the start button and nothing happens
Old Jun 16, 2018 | 05:15 PM
  #25
HackStorm's Avatar
So the atv wont shut off unless i unplug the cdi
Old Jun 17, 2018 | 02:28 AM
  #26
There is a kill wire from CDI to key switch, usually black/white, this is connected to earth by the switch. Some are earth to kill, some earth to run, either way the ignition switch should be earthing that wire in one position, and not in the other.
Old Jun 18, 2018 | 09:20 PM
  #27
HackStorm's Avatar
These are the color wires going to CDI
Attached Thumbnails SunL SLA-135-20180615_171247.jpg   SunL SLA-135-20180615_171243.jpg
Old Jun 19, 2018 | 02:07 AM
  #28
Right no black/white. Can't find a 135 diagram on the net, but the 90 diagram shows a black/white kill wire at the ignition switch, connected to a grey, which goes to CDI, see if you can find a black/white from ignition switch and trace where it goes. My guess is the middle wire, which isn't shown properly on either photo.
Dawn14320
1) Engine problems..
Apr 2, 2012 05:39 PM
paskeen
Jul 7, 2010 11:54 PM
txgal
Apr 15, 2010 10:01 PM
paskeen
Sep 2, 2009 11:23 PM
