Safety switch help
Old Jun 25, 2020 | 12:14 AM
ll3ananas's Avatar
Default Safety switch help
If i go through the wire harness and remove the safety switch wires would that make it so I wouldnt have to use the front and rear break safety's to start the quad?
Old Jun 25, 2020 | 01:36 AM
Usually you have to "jump" the wires together and this would leave the brake light on all the time. Though if you are really good at electrics, you could just jump the part of the lock-out circuit that goes to the solenoid. Not worth doing, how hard is it to put a brake on when starting?
Old Jun 25, 2020 | 08:46 AM
ll3ananas's Avatar
It's not hard I'm just trying to rule out why the bike wont start. It has bad electrical issues and I'm having a hell of a time trying to figure it out
Old Jun 25, 2020 | 09:19 AM
Zrock's Avatar
Super Quad Patrol
pull the black/white wire out of the connection at the CDI box this will bypass all the safety switches you can remove the connector right out of the plug so you can plug it back in when done testing.. Make sure to put it back when you find the issue as thats a good recipe for disaster
Old Jun 25, 2020 | 10:32 AM
ll3ananas's Avatar
Oh awesome thank you for the help
Old Jun 26, 2020 | 04:39 AM
"pull the black/white wire out of the connection at the CDI box this will bypass all the safety switches"
That wire has nowt to do with the starter circuit, not on Kids Quads anyway. Yamaha seem to wire everything through the CDI but that is perversity on their part.
Old Jun 26, 2020 | 09:00 AM
Zrock's Avatar
Super Quad Patrol
strange because thats the wire i used to use anytime i was trouble shooting. i would pop it out so i did not have to use any of the safety features and eliminate those on troubleshooting.. 3 different imports and all the same wire
Old Jun 27, 2020 | 07:46 AM
The black/white kills the spark, yes, but the OP is on about the brake switches, which lock-out the starter circuit, and except for the aforementioned Yams I have never come across a kill wire that has anything to do with the brake switches.
reaper031987
1) Engine problems..
Mar 29, 2012 12:13 AM
predmxr05
Sep 17, 2007 03:54 PM
oldsmoboat
Apr 14, 2007 01:28 PM
DaveC
Apr 18, 2004 07:02 PM
rydes400ex
Dec 26, 2000 08:13 PM
