TIRE SIZE VERSUS SPROCKET SIZE ?
Old 07-01-2000, 02:20 AM
TDBRPH's Avatar
what is the rule of thumb for changing your sprocket(s) when changing tire size? Is it necessary?
Thanks,
Triston
Old 07-01-2000, 02:24 AM
hot_shoe_cv's Avatar
Whether it is necessary or not depends on what you wish to accomplish.????
Old 07-01-2000, 02:43 AM
TDBRPH's Avatar
I am most interested in improving acceleration not top end speed and improve power for hill climbing.
Old 07-01-2000, 03:40 AM
NVR2L8's Avatar
On my 400EX I changed the front sprocket from the stock 15 to a 14-tooth for the exact same reasons, because when trail riding or at the dunes it always seemed as though I was either over-revving it or lugging it out. BTW, the 14 makes the quad pull harder at the bottom end (more torque), but does sacrifice some top end speed.
If you go to a taller rear tire though, say a 22" version, then a 14-tooth front sprocket change will bring you back (or close) to stock gearing. So if you go with a taller rear tire, you might want to lower the front to either a 13 or 14, and increase the rear to a 39 tooth for more low end power.
Bratman2
08-06-2022 01:42 AM
1986Vmax540
07-09-2021 09:53 PM
2007 Grizzley 450
08-13-2015 06:33 PM
Schneider
07-24-2015 05:05 PM
rcappie4
07-18-2015 07:51 AM
Quick Reply: TIRE SIZE VERSUS SPROCKET SIZE ?
