DID 520 X-Ring chain installation difficulty
Old 09-30-2004, 01:35 AM
Boxhead's Avatar
Default DID 520 X-Ring chain installation difficulty
There is one thing to look for before even leaving the store where you bought the chain. On the master link be sure the side plate with the pins already press fitted in it have the pins all the way in. The pins should be all the way up to the head in the plate, and should be almost flush. If the pins are sticking out of the plate a few mils, demand a different master link. You don't even need to try to put the link together, all you have to look at is the side plate with the pins already press fitted. They have some serious tolerance trouble with their master links. If those pins aren't all the way in, you'll have to press the two halves much harder together, and more than likely they won't even assemble.
Hey, aren't these chains supposed to be the best for least amount of stretch? I've already had to adjust it 3 or 4 times!!! I guess I just abuse it too much, lol.
Old 09-30-2004, 12:46 PM
quadracer18's Avatar
Ya, I remember putting my DID chain on....it was a pain in the a$$, had to use some needle nose vise grips, a flat head and some muscle.
Old 09-30-2004, 01:28 PM
FarmStud's Avatar
Been there too, used a c-clamp or vise grips to put pressure on then tapped it on with a hammer.
fordfaithful21
12-07-2015 05:52 PM
merryman
09-19-2015 03:15 AM
bmark0610
09-07-2015 09:42 PM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
toonces
09-05-2015 01:14 PM
Quick Reply: DID 520 X-Ring chain installation difficulty
