Timberwolf problem
Old Dec 10, 2000 | 09:37 AM
dkbell's Avatar
After depressing rear foot brake the brake stays locked after releasing the foot pedal any comments would be appreciated.
Old Dec 11, 2000 | 08:49 AM
BrianKimmel's Avatar
I had the same thing happen to both my front and rear brakes on my old quad, 97 Timberwolf. It sounds like the pivoting shaft that spreads your brake shoes apart may be corroded inside and not allowing it to spring back to it’s original position. Take your brake drum off and check to see that the pivoting shaft that spreads the brake shoes apart, springs back when the brake pedal is released. If not, it is probably corroded. Take the shaft out and clean any dirt and corrosion off of the shaft and then grease it and reinstall it. Then adjust your brakes. That should take care of your problem. Hope this helps.
Old Dec 11, 2000 | 10:35 AM
dkbell's Avatar
Thanks Brian I appreciate info and will try your suggestion after I get home from work tonight. I really need that bike running good as ice fishing will be starting very soon.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
