I need help with balljoints
Old Aug 27, 2002 | 10:39 PM
racer425's Avatar
Does anyone know if or what type of balljoints i can put into lonestar a arms . My local shop has nothing close to them . I have trx 250R with stock hubs with lsr +2 +1 a arms . Is there a automotive tie-rod end that works?
Old Aug 27, 2002 | 11:52 PM
desracers's Avatar
Call Lonestar and they will able to help you out.....
Old Aug 30, 2002 | 12:00 PM
Mike330R's Avatar
Ricky Stator sells ball joint also. They are the only 'true' ball joint out there.
Call him for details: 619-449-3905
Old Aug 31, 2002 | 02:54 PM
adamsmith's Avatar
I think the are 16mm, and yes there is an automotive balljoint that works it is supposedly of an old Mazda.
Old Sep 6, 2002 | 11:21 AM
POOLGUY's Avatar
Friend of mine had same problem with leagers a-arms, (word from the experienced) Leagers stuck everyone who bought his first production a-arms, they had a serious ball joint breaking problem, and when he came out with a "fix" he decided it would be too much work and not enough profit to retrofit his old arms, so he will only sell you new ones, or you can buy the new 16MM ball joints from him and fix them yourself. But anyway Ricky Stator sells the same 16mm ball joints, and we retrofitted the old leagers a-arms with them. So far no problems!
Old Sep 7, 2002 | 12:13 AM
seven's Avatar
Yes there is a auto ball joint that fits. For the lone star, They use a 79 ford courier right side tie rod end( I belive its right side but youll have to look at the thread to be sure). Leager and Jd performance and a few others use 85 VW bug right side tie rod end. I know this becouse i buy all my ball joints from the auto store as do the a arm manufacturers.Also costs half as much as getting them from the dealers!
jimk72
Aug 6, 2011 08:27 PM
cape kfx400
Feb 11, 2010 06:11 PM
Xplorer96
Oct 3, 2009 02:33 PM
Wormy400
Jul 29, 2008 02:49 PM
quadMXer70
Dec 30, 2002 09:19 PM
