How wide of tires can I go on stock foreman rims??
I know that on the older Foreman quads (the 400 models). You had to get wider rims to be able to run the 12" wide tires. Check out recreationtires.com, give them a call and ask what rim width that they mount 12" tires on (or 10" for the front. Then go out and measure your rims. If it is a newer model, you can probably do it, but a 1-800 free phonecall will answer your questions in less than 5 minutes.
Well what knid of riding do you do??
If it is just normal trail riding with some mud now and then I would suggest the bearclaws or dirtdevils.
If you drive more mud but still on hardpack trails then get gators, mud bugs or 589's
If its pure mud you drive then get highlifter outlaws or vampires.
