Dunes and Dune Machines Discussion on dunes and dune machines.
skat-trak ?
Old Apr 19, 2006 | 02:35 AM
kawiking's Avatar
Default skat-trak ?
i just bought some haulers off e-bay. they are a 20-10-10 8 paddle, im putting them on a kfx-400. do you think thats a good size to run?
my other ? is, my friend has a set of 22-11-8 gliders. my sand skate 2's are a 20 inch and they are the same height. im worried the haulers are going to be short, will i have to regear???
Old Apr 19, 2006 | 08:59 PM
SickRider's Avatar
Default skat-trak ?
they will work fine... gears should be fine too, migt wanna bring a 1 tooth less front sprocket with ya and try em both!
Old Apr 20, 2006 | 03:58 PM
kawiking's Avatar
Default skat-trak ?
ive already went 1 tooth down, i ve been running sandskate2's (v paddles) and they spin like crazy coming out of the hole(drag raceing). i was thinking of going back to stock ,but im going to wait and see how these haulers hook first. thanks for the help.
Old Apr 20, 2006 | 10:40 PM
Sandgod's Avatar
Default skat-trak ?
How many paddles are your buddies Gliders.. A Glider w/ the same number of paddles as a Hauler will slider better in the turns and actually be faster in a straight line due to the drag they don't create.. A 21" or 22" will always be faster for drags or hillshoots due to that they will float better as a 20" paddle will want to dig slightly more..
Old Apr 26, 2006 | 03:56 PM
kawiking's Avatar
Default skat-trak ?
how do you think they would do on a banshee?? stait line drag????
Old Apr 26, 2006 | 08:30 PM
Sandgod's Avatar
Default skat-trak ?
They'd work good on a Banshee.. The mega hp Banshees K&T and Dennis Packard build here in Utah run Gliders the majority of the time.. They know what works and what doesn't even w/ 100+hp.. They just use 12-14 paddles.. I just got my 8 paddle Gliders. I currently run an 8 paddle Hauler/Glider mix.. The Gliders will be a better set up..
Old Apr 27, 2006 | 12:50 AM
kawiking's Avatar
Default skat-trak ?
should i use them on the shee or go ahead and get some 22 inch haulers.
p.s. what do you think about alcohol sandgod- pm me
eRAPTOID
Jan 24, 2010 09:20 AM
JSwope
Apr 6, 2005 06:30 PM
spsocal
Oct 22, 2004 03:53 PM
JohnnySplat
Jun 14, 2004 07:27 AM
Squidward
Feb 21, 2003 10:48 AM
