banshee getting no fuel
Old Apr 20, 2009 | 11:54 PM
cutmesomeslackjk's Avatar
Question banshee getting no fuel
I just got my cylinders back from the machine shop today, got it completely back together, i have never had it running before I bought it in pieces, it will start but i have to be spraying gas into the carburetor, i have pulled them apart and cleaned the main get bowls/fuel lines, put fresh fuel in but im still not getting fuel, i have not tried to sync them but i dont know how to and i dont know if thats my problem, any help?
Old Apr 21, 2009 | 02:43 AM
Sidewinder500's Avatar
are you gettin fuel to your carbs? is your petcock turned on? to sync your carbs there is a sync window on the side of each carb along with an adjustment screw. you adjust the screws so that both carb slides are open and close precisely at the same time using your throttle
Old Apr 21, 2009 | 07:37 AM
the lines going to my carbs is clean, my petcock is on, I have fuel in the bowls, I think the are pretty close to being in sync because when I look at them they open and close and some all the way down at pretty much the same time
Old Apr 21, 2009 | 01:06 PM
ok ive got it running now, but sometimes I still have to spray a little gas in the carbs to start it, but when its running im getting really bad backfires when I let off the throttle , and i have to give it a little touch on the throttle to keep it running, its kind of ascting like its dead on one cylinder, but the engine is really jumpy kind of idleing for a sec but then it will idle up high go back down and sometimes it will just wind all the way out, btw i also put new plugs in it and that made no diffrence
Old Apr 21, 2009 | 02:44 PM
johnboy27's Avatar
kinda sounds like you have a intake leak somewhere...i'd check everything from the carbs to the engine, checks your reeds to....maybe a air leak from the case?
Old Apr 21, 2009 | 05:47 PM
ok its starting to run better now, when its setting still it will rev out just fine but i still cant really get the idle right it will die out if you just dont keep on it a little, but when im driving it and i let off the gas it backfires on the right side, after it sets for a while it dosent want to start unless you spray a little gas in breather but if its running and dies it will start right back up, there is a hose underneath my water pump where does it plug into?
Old Apr 21, 2009 | 07:36 PM
Angry
i just rode it again, its started backfiring from both cylinders, extremely loud, is there anything I can adjust on the carb?? is it broken reeds??
Old Apr 21, 2009 | 11:15 PM
johnboy27's Avatar
if it was broken reeds it would be pushing the intake charge back through the carb(s). gosh its been so long since i had my banshee i can't really remember how everthing is. how do the plugs look? i know you said they are new but maybe they fouled out already. this is a fresh rebuild so it might be a pain till the rings seat.
i remember i had carb problems on mine and got so sick of it i bought the single carb set up and it ran like a champ. when you cleaned the carbs did you just spray them down with carb cleaner or did you use a carb dip?
Old Apr 22, 2009 | 08:01 AM
I cleaned the jets in them and i sprayed them down with carb cleaner
Old Apr 22, 2009 | 09:18 AM
johnboy27's Avatar
i'd pull the carbs off and clean them really good, make sure to blow all the passages for the pilot circuits. i like to use the carb dip, take all the plastic and rubber parts off the carb then all the metal/brass parts go in the dip for about an hour...take them out give them a good spray down with carb cleaner then blow some compressed air through everything. worked great on my 250x carb that had the pilot circuit gummed up.
