26" Mud Lites..tire pressure?
Old Apr 20, 2012 | 08:02 PM
SOLOLUCKY's Avatar
Default 26" Mud Lites..tire pressure?
what do you all with Mud Lites run for tire pressures ?
I know what I run but how about others ?
I dont wanna spin them off the rim...lol
Old Apr 20, 2012 | 10:59 PM
DesertViper's Avatar
5 psi
Old Apr 21, 2012 | 07:32 AM
SOLOLUCKY's Avatar
...cool...5 is what i picked...
Old Apr 21, 2012 | 10:24 PM
cbrandon's Avatar
I sometimes run as low as 3.5 psi in mine if I want The extra give for climbing over rocks or The little bit of extra traction for mud. And have had no problems as of yet.
Old May 2, 2012 | 06:44 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
4 psi over rough / rocky terrain- up to 6 or 7 psi in dirt & mud...
Old May 2, 2012 | 07:27 AM
Around 6 or 7 usually.
Old May 2, 2012 | 11:21 AM
Deeperinthabush's Avatar
If riding on hardpack,rocks,or hard trails usually at 3-3.5 psi,but for mud,sand,water,etc I up them to 9.5-10 psi...
Old Jul 13, 2012 | 01:27 AM
Steele3's Avatar
3psi. for hard stuff, 10 for deep water/mud
I have heard of running 0-psi. but havent tried it., might spit a bead though. Why I havent pulled the cores.
Old Jul 13, 2012 | 11:26 AM
I can guarantee you that with Mud Lites,and almost any atv wheels(other than bead locks) you'll lose the beads before you can go anywhere...Also, riding an atv with a flat tire is the easiest way to destroy the tires carcass...Last set of ITP Mud Lites I owned(27,or 28s) would pop off the ITP wheel beads if they were under 2 psi with a simple turn of the bars...
Old Jul 13, 2012 | 11:55 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
how do you run a flat (0psi) tire?
unless it's in deep mud 100% of the time or it has 12 ply side walls- who ever told you that is smoking some bad stuff even my 30" 6 ply silverbacks will fold or pinch with zero psi in the tire- not to mention, you'd have zero control over the steering and handling in any trail.
ever try to ride an atv bact to the truck with a hole in it? not fun. even 2psi is pushing fate- very easy to fold & pinch the sidewall under 4 psi on most atv tires.
bmxatv10
Oct 14, 2022 06:23 PM
Alex G.
Sep 11, 2017 11:38 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
