twister hammerhead 150cc go off road go kart
#51
here's a pic of the new tires they are putting on these,
mine looks just like this one (except the blue looks a whole lot better in person).
http://www.menintools.com/images/twister5.jpg
#52
#53
Hi,
I was wondering if anyone has checked the speed on their Hammerheads. I have used both a GPS unit and installed a bicycle speedometer on the kart. Both of these read 30 mph on asphalt going down a slight incline. Advertised speed is 36+ for this kart. I have an email out to tjpowersports to see if they have any thoughts. I checked the plug and it looks like the mixture is fine so I would hate to try and just lean it out. Anyone else check speed?
Thanks
Thanks
#54
Originally posted by: rmvd69
Hi,
Thanks
Hi,
Thanks
I've checked both my Yerf-Dog 3206 and my KPX Xterro with a GPS. Both clocked in at 31 MPH.
#55
Originally posted by: RAPTORAZ
Those look like they'd work much better than the stock ones that came on my KPX's. What size are they?
My tires say 22-10-10 on the side, look the same size as my Hondas, I think they are taller than last years version, this may make top speed slightly higher. They do a nice job of tearing up the bermuda grass I call a lawn. Also I like the square profile of them, I think they have too much air in the one in the picture because mine look perfectly flat on top. I will be testing them out this weekend hopefully on some real trails. I am not sure if I should change the oil before then. I only have 45 fairly easy minutes on the engine but want it to last. Someone said the stock oil was pretty wimpy. I doubt I can ride it for much longer without getting on it, especially in the woods. I told my wife if this one is as much fun in the woods as I think its going to be I may order a cheaper (and lighter) single seat version but she said if I do that she wants one for her and our other boy to ride in.
#56
Yes on that oil. I have found, fairly universally, that Chinese/Tiawanese motor producs come with very thin oil. Something like 20 weight. [img]i/expressions/face-icon-small-shocked.gif[/img]
i DRAIN THEM AND PUT IN 30w for break in, and 50W for running. In these, cheap oil, I think, is best. The cheap brands don't put in the additives that the expensive ones do, which is better for a wet clutch.
#57
Since these karts don't have a wet clutch, any automotive type oil will do fine. I'm running Royal Purple 15W-40 synthetic in the engine. And Royal Purple gear oil in the gear case.
#58
While we are on the subject of oil I have a problem that I hope someone can help with. The "bargain" KPX 150 that I bought on Ebay arrived yesterdsay. I assembled it and fired up the engine...all seemed fine. It was 10:00 at night and my kids were flying around the yard and driveway for about an hour. We put it in the garage for the night and noticed a large amount of oil dripping out of the plastic housing that protects the clutch/flywheel/fan and the rest of the motor was drenched in oil as well. I disassembled the housing and the leak appears to be coming from behind the clutch pack (passenger side of engine). I assume the eqivalent to a cars rear main seal is the culprit but I'm not sure. Has anyone had this problem?
I attempted to remove the clutch pack but couldn't budge the nut, I think it was an 18mm. The cover behind the clutch is mounted with a series of 9mm bolts but I think I need to remove the clutch first. THis is the cover where the inductive pick up mounts to the engine in order to read the flywheel. Any suggestions are appreciated?
P.S. I did notice that the crankcase was over filled with oil from the factory but I doubt this is a contributing cause.
#59
http://f6.grp.yahoofs.com/v1/sDBWQcy...viceManual.pdf
#60
Thanks for the link but I got a page not found message rather than a log in screen as I do have a Yahoo Acct. COuld you post one more time. Thanks. The oil level is correct now but it's still leaking. That seal must be the culprit I just can't get the clutch pack off.
