Help With Forum Software! A Place to get Help with the Forum.
LT80 Clutch adjustment... HELP!
Old 11-21-2010, 04:16 PM
cbeery's Avatar
Default LT80 Clutch adjustment... HELP!
I recently replaced the V-Belt on my son's 2001 LT80...Aditionally, replaced a number of parts due to damage/rust including; plate and spring limiter, Movable Drive face rollers (4) and plate, cover, o-rings.
I tried to salvage; Clutch Assembly (cleaning rust off springs, backing plates etc.) the pads didnt look too bad (have been replaced by previous owner as well as modification to taking out 2 rollers from Dr.).
After i put all back together all seemed to be in working order according to manual. However when i tightened the last nut which holds the Clutch housing, Plate and Spring Limiter the rear axle seizes (will not rotate). I loosen the nut and it turns normally.
Torque on this nut is 30-45 lbs. even when not torqued (hand tightened) same results as above mentioned.
Any advice, corrections will be greatly appreciated. Family is hoping to go riding (camping) over the T-Giving Holiday.
Thank you in advance.
Craig
buddieboy
12-09-2016 05:50 PM
QuadRiders
10-22-2015 04:13 PM
tysonbully
09-28-2015 02:30 AM
jbrewster94
09-23-2015 04:16 PM
merryman
09-19-2015 03:15 AM
Quick Reply: LT80 Clutch adjustment... HELP!
