PLEASE HELP on Rancher!!!!!!!
Old Jul 7, 2003 | 08:30 PM
peloft's Avatar
Default Please HELP on Rancher
I posted this a while back but couldn't find the post.
I was riding in a river on my 2000 rancher 4x4 and fell in a whole and got stuck, my friends told me to keep it running in the water, so I did ( I think I should have killed it ) . When we got it out we unhooked the spark plug and tried to drain it. It started working but white smoke was coming out of the exhaust and it would back fire a lot but it would still go, now when I trie to ride it it wont go over 4 mph and then it will die, it will also die when I rev it in nuetral. We changed the oil, drained the gas and I cleaned out the air box, tomorrow I am getting a new spark plug. What can I do to make it run again? Thanks.
Old Jul 8, 2003 | 12:22 AM
peloft's Avatar
Default PLEASE HELP on Rancher!!!!!!!
Anyone know how to fix it?
Old Jul 8, 2003 | 12:59 AM
WISTECH's Avatar
Did you drain the carb to?
Old Jul 8, 2003 | 01:04 AM
peloft's Avatar
No, how do I do that? And it's been messed up for about 3 months.
Old Jul 8, 2003 | 03:06 PM
peloft's Avatar
bump
Old Jul 8, 2003 | 05:08 PM
GoldenChild's Avatar
To drain it you need to pull the carb. I don't recall if that required disconnecting your throttle cable and choke cable, but if you can get away without doing that it's a lot easier. You will need to pull some plastic for ease of access, also your seat too. When you get the carb pulled (make sure your fuel switch is "off"), unscrew the 4 screws that hold the float bowl and pour out the fuel. If you can do it, a shot or two of carb cleaner in there wouldn't hurt. Then put everything back together.
I'd look up a parts diagram on the computer, if you don't have a service manual, to get an idea what to look for. It's fairly simple, just take your time and pay attention to what parts go where.
Last tip, if it's real muddy, wash everything around your carb first, and put a clean rag into each hole the carb came out of while you are working on it.
Old Jul 8, 2003 | 06:19 PM
peloft's Avatar
I forgot to say this happend about 3 months ago.
Old Jul 8, 2003 | 06:46 PM
peloft's Avatar
It wont even start now, we just changed the oil, put in a new oil filter and spak plug and put in gas cleaner and it still wont start up.
Old Jul 8, 2003 | 09:26 PM
Will the motor turn over?
Old Jul 8, 2003 | 09:40 PM
peloft's Avatar
It'll start to run now but it acts like it isn't getting any gas. I have to put it on choke to start it tho and it usually dies when i put it into 1st gear. It hasnt been fired up in a while tho.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
