Honda Carb
Old Aug 14, 2003 | 02:52 PM
lesnes's Avatar
Default Honda Carb
I have a 88 honda and its been sitting for about 2 yrs. And i yanked the carb off and cleaned and put it back on and it runs better, but not good enough. It will idle sort of ok but when you give it about half throttle it will stick. So i thought its the cable, but its not. And when you go to change gear its idleing to high. So adjusted the idle but then it dies. so i put it back and it does the same. It take to long to return to idle. Please help!!
Old Aug 14, 2003 | 03:03 PM
HA2's Avatar
HA2
Default Honda Carb
u might have reinstalled the slide wrong, happens all the time.
Old Aug 14, 2003 | 04:22 PM
lesnes's Avatar
Default Honda Carb
Well i looked and it can only go one way, unless im not seeing it
Old Aug 14, 2003 | 04:43 PM
KGB's Avatar
KGB
Default Honda Carb
I am thining of float level. Or possible gunk stuck in somewhere. I know the best remedy for stock 250r carbs is to remove from bike and deposit in a trash can.
Old Aug 14, 2003 | 05:28 PM
HA2's Avatar
HA2
Default Honda Carb
dont know why you say that, my carb has never gaven me any problems.
you're right about the slide only going in one way, but sometimes the people get the spring on wrong, it's hard to explain but it causes for just about WOT idle. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 14, 2003 | 05:53 PM
lesnes's Avatar
Default Honda Carb
Well i see that the spring can really go only one way also. But maybe i'm not see the the right way.
Old Aug 14, 2003 | 06:02 PM
HA2's Avatar
HA2
Default Honda Carb
so you're saying you rev it up and it takes a long time to return to idle? and when it does idle it's really high?
Old Aug 14, 2003 | 06:04 PM
lesnes's Avatar
Default Honda Carb
No i got it to where its not to bad.
Jmuddin284
Jan 19, 2026 07:16 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
