All stock but the filter? Is it worth rejetting?
Old Aug 30, 2003 | 03:53 AM
MudStud's Avatar
Default All stock but the filter? Is it worth rejetting?
I just got my wife a 2002 400EX and it's stock but it has a foam filter. I hate foams. I run K&N in the DS and want to put a K&N in the EX also simply to keep it the same and cleaning. I can almost bet we wont be suping hers.. So, am I fine with the curent jetting from the factory... Lid and everything will stay on...
Old Aug 30, 2003 | 04:03 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Honda jets lean at the factory. Even a little more air might push it to far?????
Old Aug 30, 2003 | 04:08 AM
MudStud's Avatar
Could I just get away with moving the needle up? the main only works on the WOT anyways....... What is the stock filter? I wonder if what I have is stock, I highly doubt it..
Even with the lid on it will flow enough air to require jetting?
Old Aug 30, 2003 | 12:39 PM
yellowexracer's Avatar
U could do a plug check and see if its running lean?
Old Aug 31, 2003 | 08:53 PM
cals400ex's Avatar
you may want to go up on the mainjet from a 148 to a 150. in the middle of summer, the 148 should work fine. in winter, when the air is more dense, a 150 might be better. i would leave the needle in the factory position and turn the fuel skrew out 3 to 3.5 turns from it being lightly seated.
Old Aug 31, 2003 | 09:13 PM
redranger1's Avatar
hey cals400ex, are you sure thats right about the jetting during summer and winter? i know that on my uncles pullin truck we richin the carb up as the weather gets cooler, if we dont the headers will glow because it runnin to lean. anyhow, i think it is supposed to be more fuel during winter and less during summer. nathan
STLyamwar
Jul 25, 2020 04:44 AM
Ronk407NY
Feb 13, 2016 11:05 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:43 PM
